Hilfe!
Diskutiere Hilfe! im 2 Ventiler Forum im Bereich Motorrad Modelle; Hello, I am underway from Norway to Morocco on my newly restored R 80 G/S (1981). Today I was riding trough Denmark and experienced that the oil...
N
Norwegian
Hello,
Today I was riding trough Denmark and experienced that the oil lamp came on.
at high RPM there was only a small glow, but at idle speed the lamp was fully on.
And it keeps getting worse. Now it looks like the lamp is on all the time.
From what I can gather, the problem must be the o-ring on the oil filter and I need to change it.
I am now in Hamburg and have a ticket with the train tomorrow after noon.
Does any one know if I can get a filter and gaskets in Hamburg tonight or in the morning? Before 12 o'clock?
Need oil as wel... :(
best regards from a desperate Norwegian :)
blackbeemer
I live 80km north of Hamburg and have the parts You need.
Can You ride to me tomorrow in the morning?
N
Norwegian
Not sure if it is safe to drive that far. Can I take a train? I have to be back in Altonna and embark the train at 1305 hrs.
Gast 7673
Just take care that there is no Problem in connection with the oil suspension …
This COULD be a symptom of a wrong bearing.
Take it easy and keep the rpm in the mid-range..
If the O-Ring is the Problem, there is a good chance of a reduced oil pressure and that could do some harm in the near future !
Benno
Benno
Dülmen/Münsterland
F 650 Twin GS / C 650 GT
Does the engine still work? I'm in fear, that it could be already destroyed.
Gast 7673
Jep !
Sounds like a severe problem
Question : Does the light dim (or is it off) whenever You speed the engine? That is a sign of a problem in the oil-circulation..
If it's ON all the time, there is a severe chance of damaging the main bearings of the shaft..
Benno
Benno
Dülmen/Münsterland
Ich denke mal, der Motor ist hin. Er schreibt, wenn ich das richtig verstanden habe, von deutlich zunehmenden Problemen. Weiterfahren mit dem Zug würde ich nicht.
Gast 7673
BTW … Are You shire that the light is the control-lightof the oil pressure? Or COULD it be that there is a glowing light of the generator …
These old bikes tend to have a problem with this ..
Gast 7673
Kann gut sein Benno.. Aber evtl verwechselt er auch die Anzeige oder das HAuptKW Lager ist etwas zu groß dimensioniert einsetzt worden (macht man ja gern) dann KANN er Glück haben.
Wenn nur der Distanzring des Ölfilters zum Gehäuserand fehlt oder die Dose zum Gehäuse sich gesetzt hat, könnte es harmloser sein.
Würde auch nicht weiterfahren ! Ohne Klärung
Benno
Benno
Dülmen/Münsterland
If you are sure that your problem is the filter, you can take the train. The filter will be available all over Europe in a few days. But if there is a risk of a damaged engine, I wouldn't take the train.
Benno
Benno
Dülmen/Münsterland
@Dirk: Ich denke, wir denken das Gleiche. Hoffentlich hat er sich mit der Lampe vertan, wenn nicht, müsste der Motor eigentlich längst hin sein.
N
Norwegian
The light goes almost off when I speed up (100km/h & 5th gear).
the engine runs just fine, but I am worried about the oil circulation.
Oil filter was changed not so long ago. <1500 km.
Maybe I could rent a car and drive up? I guess it is possible to there and return to Altonna in 4 hrs?
V
vierventilboxer
R1100S, 450EXC, SB6
Hello Norwegian!
I'm relatively sure that you only have filled in the wrong oil.
Consider the temperatures in D and specifically in Morocco - you need a 20W50 Oil or anything else.
It would be advantageous if you accept blackbeemer`s offer. Change oil (and if possible also the filter).
V
vierventilboxer
R1100S, 450EXC, SB6
Dann ist es egal, denn damit ist die Tour definitiv gelaufen. Wollen wir es mal nicht hoffen!
N
Norwegian
Since this started, the bike has done more than 500 km and it does not appear to be overheated in any way. At least not that I can see. I had several stops, where it cooled off, and it started again just fine.
Can a faulty bearing trigger the light? By the way, it is not the charging light I am looking at. I can see how they can be mixed up.
I use 10w40 oil that I got from boxerparts.
blackbeemer
If You will ride to me, this are my coordinations:
N54.12390 E9.62306
N
Norwegian
Detlev,
Thanks again for your help.
I followed your advice and managed to download the BMW repair handbook. No more "Haynes" for me.
the engine still runs fine, and sometimes, especially at high speed, the light goes off.
Reading the book, it says that low pressure could be because the over pressure valve is stuck in open position.
then I remembered that the old filter had collapsed. Such high pressure could have opened the safety valve?
do you know if we checked the over pressure valve?
best regards, Karl
blackbeemer
Hi Karl,
no, we didn´t check the overpressure-valve. It´s located under the chaincase in the front of the motor.
Hilfe!
Hilfe! - Ähnliche Themen
  • Sena 20S Evo brauche Hilfe bei den Verbindungen
    Sena 20S Evo brauche Hilfe bei den Verbindungen: Hallo zusammen, ich hatte es einmal hinbekommen aber nachdem ich aus Versehen alle Verbindungen gelöscht habe klappt es nicht mehr. Komponenten...
  • Biete Sonstiges Zu verkaufen: Dürkopp MD150, Victoria KR20, NSU FOX 125, Göricke 100K - Hilfe an die Witwe aus Anlass eines Sterbefalls
    Zu verkaufen: Dürkopp MD150, Victoria KR20, NSU FOX 125, Göricke 100K - Hilfe an die Witwe aus Anlass eines Sterbefalls: Hallo Oldie-Liebhaber! Für eine Bekannte möchte ich diese Motorräder zeigen: Dürkopp MD 150, Baujahr 1953 Victoria KR 20, Baujahr 1933...
  • Hilfe - Sitzbank
    Hilfe - Sitzbank: Hi, Ich hab mich jetzt schon durch so einige Threads gequält, bin aber noch nicht schlau genug um zu entscheiden. mein Problem: Ich fahre eine GS...
  • Hilfe gesucht für einen 3D Druck
    Hilfe gesucht für einen 3D Druck: Moin, zu Coronazeiten habe ich im Look down einen Lego Mellenium Faclon zusammen gebaut (75192). Nun suche ich jemanden mit einem 3D Drucker, der...
  • Hilfe benötigt, Keyless Go ist TOT
    Hilfe benötigt, Keyless Go ist TOT: In einem anderen Thread fragte ich bereits wegen der Schlüsselprobleme und berichtete das ich auf den Werkstatttermin warte. Sodele, nun geht...
  • Hilfe benötigt, Keyless Go ist TOT - Ähnliche Themen
  • Hilfe - Sitzbank
