Hilfe!
Diskutiere Hilfe! im 2 Ventiler Forum im Bereich Motorrad Modelle; Sorry, I meant the little bypass valve that sits just inside of the filter. According to the book, if this valve is stuck in open position and/or...
N
Norwegian
Sorry, I meant the little bypass valve that sits just inside of the filter. According to the book, if this valve is stuck in open position and/or does not seal properly, then it can lead to low oil pressure. But I find it hard to understand, because all the fluid will still have to pass trough the same "bottleneck" before it reaches the pressure switch. If the pump delivers the correct amount of flow, then pressure would have to build up again after passing the bypass valve (if it is open)?
By the way; is the outer rotor on the pump secured by a .....? I cannot find it in any spares list or shops.
The bike is parked now. I have contacted a German BMW mechanic who will fix the bike when he gets back from vacation.
it still runs fine and the are no strange sounds. In the end, before I parked it, the oil lamp went off again and acted normal except for same vague glow when I accelerated.
N
Norwegian
Looks like a word fell out?
Is the outer rotor secured by a small threaded/countersunk bolt?
blackbeemer
No, the outer roter runs free.
The bypassventil is only working for the filter, wenn this is open, the filter will not work, but the oilpressure must be ok.
Try this too: throw down the cable from the oilpressureswitch and turn the ignition on. If the lamp will glow now, ist only an electric problem.
Hilfe!
Hilfe! - Ähnliche Themen
  • Biete Sonstiges Zu verkaufen: Dürkopp MD150, Victoria KR20, NSU FOX 125, Göricke 100K - Hilfe an die Witwe aus Anlass eines Sterbefalls
    Zu verkaufen: Dürkopp MD150, Victoria KR20, NSU FOX 125, Göricke 100K - Hilfe an die Witwe aus Anlass eines Sterbefalls: Hallo Oldie-Liebhaber! Für eine Bekannte möchte ich diese Motorräder zeigen: Dürkopp MD 150, Baujahr 1953 Victoria KR 20, Baujahr 1933...
  • Hilfe - Sitzbank
    Hilfe - Sitzbank: Hi, Ich hab mich jetzt schon durch so einige Threads gequält, bin aber noch nicht schlau genug um zu entscheiden. mein Problem: Ich fahre eine GS...
  • Hilfe gesucht für einen 3D Druck
    Hilfe gesucht für einen 3D Druck: Moin, zu Coronazeiten habe ich im Look down einen Lego Mellenium Faclon zusammen gebaut (75192). Nun suche ich jemanden mit einem 3D Drucker, der...
  • Hilfe benötigt, Keyless Go ist TOT
    Hilfe benötigt, Keyless Go ist TOT: In einem anderen Thread fragte ich bereits wegen der Schlüsselprobleme und berichtete das ich auf den Werkstatttermin warte. Sodele, nun geht...
  • Brauche Hilfe! Kardan & HAG defekt!
    Brauche Hilfe! Kardan & HAG defekt!: Vor einer Woche noch mal die Batterie geladen, damit ich heute sicher zur Wartung fahren konnte. Dann heute morgen die GS (K25, TripleBlack, Bj...
  • Brauche Hilfe! Kardan & HAG defekt! - Ähnliche Themen
  • Hilfe - Sitzbank
