R80/100GS front fork mounted on R80G/S (TüV or BMW approval)
Diskutiere R80/100GS front fork mounted on R80G/S (TüV or BMW approval) im 2 Ventiler Forum im Bereich Motorrad Modelle; Hi 2V riders I have a BMW R80 G/S and would like to mount the front fork from a BMW R80/100 GS but I will need to have it certified for legal use...
G-slash-S_Rider
Hi 2V riders
I have a BMW R80 G/S and would like to mount the front fork from a BMW R80/100 GS but I will need to have it certified for legal use on the road. The front wheel will still be from the G/S with a special front axle and brake parts from HE Bremstechnik.
  • Does anybody know if any German riders have done the same conversion and had it TüV approved?
  • Or does anbody know if BMW has made an official approval of using the R80/100 GS forks on a R80 G/S?
Hope that some one can help me with some answers or point me in a direction where I can find some more information on how to get the conversion approved for road use in Europe!
Hermann (aus E)
Hermann (aus E)
Essen
Hi Slash,
I think there are some bikes with that combination, but not in this forum. Ask the real specialists in the forum 2V-Frorum >> click <<
Greetings Hermann
DiDi 60
DiDi 60
Südwestpfalz, dort wo die vielen Kurven sind
R 80 G/S Bj. 81, R 1200 GS Bj. 14
i have mounted a front fork from the R 100 GS in my G/S and use the original front wheel from the G/S. Using the fork is very easy, like plug & play. To use the front wheel from the G/S in this fork is very difficult, you need a selfmade axle and have to change the brake parts. I use a brake disk from the R 100 GS with a new circle of holes and have to modify the brake caliper.
I am very certain that there are no certificates from BMW for this conversion, sorry.
G-slash-S_Rider
Vielen Dank fur die antworte Hermann!
I will try to investigate further in the other 2V forum. There is no question that the GS forks and brakes offer far better riding safety than the under dimensioned G/S parts. I would just like to apply to all rules and regulations.
@DiDi 60: Your conversion looks superb! I hope you could help me with below questions:
- Did you use the original G/S hub to bolt your new disc to?
- Where did you order your disc and do you have any part number created for it?
- Did you get the conversion TÜV approved/road approved?
Thanks in advance!
I found this website where the conversion is described: Daniel Dickes R80G/S
The guy is writing the text below on the site so I will try to contact him:
"Die TÜV-Eintragung war kein Problem. Bei Bedarf kann ich eine Briefkopie versenden und mit Unterlagen für die Eintragung behilflich sein."
DiDi 60
DiDi 60
Yes i use the original hub in the G/S - front wheel.
- fork from R 100 GS
- complete front wheel original from G/S
- the braking disk BW02FI from braking company https://www.braking-shop.eu/brakedisc/bw02fi
- the braking caliper from Brembo with 32/34 mm pistons
My conversion works very well and i never need a approval for my local TÜV here.
If you want to do exact this conversion think twice, it is not easy to do and was very difficult for me.
- you have to made a new axle
- you need some new selfmade distance washers for the left an the right side
- to mount this braking disk you need the holder of an original brake disk from BMW R 100 GS or other BMW
- you have to drill some new holes in this holder (GS: 4 x 10 mm ....., G/S: 5 x 8 mm .....)
- you have to mill-cut 4 mm less at the two holder at the braking caliber
I was very happy to have some good friends in mechanical engineering to do this conversion!
G-slash-S_Rider
Thanks a lot for the details :-) I do have some contact to local machine shops but I'm not expecting it to be cheap. Still I'm willing to spend the money and time to improve my G/S!
R80/100GS front fork mounted on R80G/S (TüV or BMW approval) - Ähnliche Themen
  • Erledigt Edelstahlauspuff R80/100GS
    Edelstahlauspuff R80/100GS: Hallo zusammen, bin auf der Suche nach einem R80/100GS Edelstahlauspuff. Alles anbieten. Danke und schöne Grüße
  • Erledigt 320mm Bremsscheibe R80/100GS komplettes Set Neu - Unbenutzt
    320mm Bremsscheibe R80/100GS komplettes Set Neu - Unbenutzt: ich habe hier ein 320mm Bremsscheibe R80/100GS komplettes Set mit Bremszangenadapter. Inkl. ABE ! Das Set ist neu und noch nicht verbaut worden...
  • Biete 2 Ventiler Gabelfedern R80/100GS progressiv Komfort
    Gabelfedern R80/100GS progressiv Komfort: Gabelfedern R80/100GS progressiv Komfort
  • Erledigt Därr Aluboxen für BMW R80-100GS und PD in sehr guten Zustand
    Därr Aluboxen für BMW R80-100GS und PD in sehr guten Zustand: Verkaufe Därr Aluboxen für BMW R80-100GS und PD und auch G/S in sehr guten Zustand. Die Boxen können mit einer kleinen Platte an den originalen...
  • Suche Touratech Kofferträger R80 / 100GS
    Touratech Kofferträger R80 / 100GS: Hallo Zusammen, ich suche einen Kofferträger der Firma Touratech für die BMW R80 / 100GS. Die Artikelnummer lautete 01-051-0020-0. Leider hat...
  • Touratech Kofferträger R80 / 100GS - Ähnliche Themen
