Ergebnis 1 bis 5 von 5
Möglicherweise Interessant: Wassereintritt in benzinpumpe
Erstellt von mr.spock, 13.04.2005, 00:25 Uhr · 4 Antworten · 1.690 Aufrufe
    09.02.2005
    Standard Möglicherweise Interessant: Wassereintritt in benzinpumpe
    aus einem anderen Forum:
    However, the following recent service information, sent out to dealers, has recently come to my attention:
    Situation:
    Water ingress past the blue O-ring into the cavity underneath the fuel pump electronics.
    This can cause sporadic failure of the fuel pump unit.
    Hazardous situations could result if the engine were to cut out unexpectedly and possibly start firing again just as suddenly.
    Series Solution:
    As a provisional measure adopted in series production since July 29, 2004, a black O-ring seal that is 2mm shorter around has been installed: this O-ring solves the problem and does not have to be replaced.
    As of VINs ZR20403 (ECE) and ZL78234 (US), motorcycles leaving the factory have new turquoise-coloured profiled seals that definitively solve the problem
    Models affected:
    R1200 GS ((ECE)europe) VINs from ZL25000 to ZL29999 and ZN25000 to ZN31286
    R1200 GS (US) VINs from ZL75000 to ZL76160
    If your's falls within these VINs you should receive a recall notice from your main dealer for a replacement seal to be fitted. If you do not receive anything contact them and quote the above service information number.
    gruss
    dietmar
    26.01.2005
    Moin Dietmar,
    gab's denn genau deshalb nicht schon nen Rückruf?
    Mikele
    09.02.2005
    moin!
    möglich, habe auf jeden fall in diesem forum nix davon gefunden, deswegen hab ichs hier mal eingebracht. da meine SN nur "knapp" ausserhab der grenze der betroffenen bikes ist (habe meine im april 05 abgeholt) wars für mich interessant.
    lg
    dietmat
    17.03.2005
    Ja, es gab eine Rückrufaktion.
    Mein Hirsch war auch davon betroffen.
    26.01.2005
    Hi Alex,
    eben, meine Gute doch auch!
    Mikele
  1. Nennen wir es interessant.....
    Von TobyG im Forum Smalltalk und Offtopic
    Letzter Beitrag: 04.06.2012, 20:09
  2. Antworten: 13
    Letzter Beitrag: 28.04.2010, 21:12
  3. Wassereintritt beim Schuberth C3
    Von Bluebeauty im Forum Bekleidung
    Letzter Beitrag: 29.06.2009, 14:34
  4. Suche Möglicherweise...
    Von adschi99 im Forum Suche/Tausche (privat) ...
    Letzter Beitrag: 15.05.2009, 18:28
  5. Möglicherweise Interessant: Gaszugblockade
    Von mr.spock im Forum R 1200 GS und R 1200 GS Adventure
    Letzter Beitrag: 14.04.2005, 14:16
