Möglicherweise Interessant: Wassereintritt in benzinpumpe
Diskutiere Möglicherweise Interessant: Wassereintritt in benzinpumpe im R 1200 GS und R 1200 GS Adventure Forum im Bereich Motorrad Modelle; aus einem anderen Forum: gruss dietmar
mr.spock
However, the following recent service information, sent out to dealers, has recently come to my attention:
Situation:
Water ingress past the blue O-ring into the cavity underneath the fuel pump electronics.
This can cause sporadic failure of the fuel pump unit.
Hazardous situations could result if the engine were to cut out unexpectedly and possibly start firing again just as suddenly.
Series Solution:
As a provisional measure adopted in series production since July 29, 2004, a black O-ring seal that is 2mm shorter around has been installed: this O-ring solves the problem and does not have to be replaced.
As of VINs ZR20403 (ECE) and ZL78234 (US), motorcycles leaving the factory have new turquoise-coloured profiled seals that definitively solve the problem
Models affected:
R1200 GS ((ECE)europe) VINs from ZL25000 to ZL29999 and ZN25000 to ZN31286
R1200 GS (US) VINs from ZL75000 to ZL76160
If your's falls within these VINs you should receive a recall notice from your main dealer for a replacement seal to be fitted. If you do not receive anything contact them and quote the above service information number.
gruss
dietmar
Mikele
Mikele
Marktoberdorf
R1200GS
Moin Dietmar,
gab's denn genau deshalb nicht schon nen Rückruf?
Mikele
mr.spock
moin!
möglich, habe auf jeden fall in diesem forum nix davon gefunden, deswegen hab ichs hier mal eingebracht. da meine SN nur "knapp" ausserhab der grenze der betroffenen bikes ist (habe meine im april 05 abgeholt) wars für mich interessant.
lg
dietmat
Alex
Alex
R 1200 GS
Ja, es gab eine Rückrufaktion.
Mein Hirsch :lol: war auch davon betroffen.
Möglicherweise Interessant: Wassereintritt in benzinpumpe - Ähnliche Themen
  • Interessanter Umbau
    Interessanter Umbau: Eine Version, wo der 1800er gut untergebracht ist. Legendary BMW 328 Inspires ShiftCustom's R 18 Retro Reverse Trike
  • BMW Rückruf Möglicherweise undichte Benzinpumpe
    BMW Rückruf Möglicherweise undichte Benzinpumpe: Kennt jemand das Thema und hat schon Infos für Deutschland ?? BMW muss in den USA rund 17.000 Motorräder verschiedener Baureihen zurückrufen...
  • Rumor: Prototyp R1300GS, möglicherweise schon 2021 im Handel?
    Rumor: Prototyp R1300GS, möglicherweise schon 2021 im Handel?: https://youtu.be/4r_E1iQOVWE :rolleyes: Scnr ;)
  • Suche Möglicherweise...
    Möglicherweise...: hat jemand von euch - eine sogenannte "freier Blick auf´s Hinterrad" Blende inkl Schrauben (es gibt ja Bastler im Forum), und - einen...
  • Möglicherweise Interessant: Gaszugblockade
    Möglicherweise Interessant: Gaszugblockade: Für jeden, des es betreffen kann (falls noch nicht bekannt) Gruss Dietmar
  • Möglicherweise Interessant: Gaszugblockade - Ähnliche Themen
