dt857171
- Dabei seit
- 24.09.2025
- Beiträge
- 6
1. Can I switch my final destination after booking a connecting flight?
Yes, you can switch your final destination after booking a Lufthansa connecting flight. The fastest route is calling
Switching destinations isn’t the same as changing travel dates. It involves reissuing your ticket with the new routing, which often requires recalculating the fare difference. If the new destination is more expensive, you’ll pay the difference in addition to any applicable fees. On the other hand, if the new city is cheaper, Lufthansa generally won’t refund the difference.
It’s smart to decide early, since costs often rise the closer you get to departure. Some passengers call immediately after booking to explore alternatives, while others wait until closer to their trip in case plans shift again.
One helpful tip: not all routes allow destination changes mid-connection. For example, if your ticket was issued under a special fare contract, options may be limited. To get real-time details, call
2. What rules apply if I want to change only my connecting city?
When passengers want to change just the connecting city, specific rules come into play. The process begins with a call to
Switching a connecting city is not always treated the same as changing a final destination. Sometimes, it’s seen as a simple rerouting; other times, it’s considered a full modification. This depends on how your ticket was originally priced. Some discounted fares lock you into a specific route, making connection changes harder or more expensive.
It’s important to note that Lufthansa prioritizes fare rules above personal preference. If your ticket allows routing flexibility, you’ll usually get a new option at a fee plus any fare difference. But if your ticket is restricted, you may need to upgrade to a more flexible fare to adjust your connecting city.
Timing also matters. Changes made well before travel usually have more options. Last-minute changes, particularly after your trip has already started, may be limited. For instance, if you’ve already flown the first segment, adjusting the middle portion becomes more complex.
To avoid confusion, the best approach is calling
3. Does Lufthansa allow destination changes after travel has already begun?
Yes, destination changes after travel begins are possible, though more complicated than pre-departure modifications. The first step is contacting
Once you’ve flown the first segment, your ticket is partially used, which limits flexibility. For example, some fare rules lock in routing after the trip starts, meaning only date changes are permitted, not destination changes. Others may allow you to change the onward or final city, but fees and fare differences typically apply.
If Lufthansa approves the switch, your ticket is reissued with the new destination. This reissue recalculates your total fare, and you’ll pay any difference compared to your original booking. Keep in mind that once travel has started, refunds for cheaper destinations are rare. Instead, you’ll almost always be responsible for paying extra if the new city costs more.
It’s worth noting that mid-journey destination changes can sometimes disrupt checked baggage routing. If you’ve already checked luggage, the process requires coordination to ensure your bags follow the new path. Because of these logistics, early notice is crucial.
The safest strategy is always calling
