problem mit den GS r 1250 bremsen
Diskutiere problem mit den GS r 1250 bremsen im R 1250 GS und R 1250 GS Adventure Forum im Bereich Motorrad Modelle; Hello to all forum members. I'm Stefano and I write from Italy. I have a recent problem with my bike's front brake. I currently have 14,000 km and...
StefanoVisentini
I have a recent problem with my bike's front brake. I currently have 14,000 km and for about 2,000 the braking has been irregular at low speed (<30Km/h) and up to the stop. It's as if braking comes and goes, as if I pull and release the brake. But I'm not! This only happens in gentle braking, if I brake harder the problem does not exist.
The bike does not have oval discs, and wear is minimal. I usually travel on stretches of motorway and only rarely on challenging passes and descents.
The bike was tested by an official BMW technician who detected the "problem" but found no reason to intervene under warranty saying that all GS bikes have that problem after a few km. It seems to me an unreasonable explanation. I would like your opinion please.
Thank you
//Mod edit: Überschrift auf Deutsch umgestellt
My experience on a different BMW Motorrad motorcycle (K25) with the very same problem repeatedly: Distorted brake rotors have always been the root cause for these symptoms on my motorcycle.
After replacement under warranty it reoccurred a second (warranty again) and a third time (dealer refused to replace under warranty now) until I finally changed the rotors on my own expenses with a different "brand" (in my case not really brand related) instead of BMW Motorrad Brembo discs I took Brembo's Serie Oro as the official Brembo after market replacement for this motorcycle. These rotors are 0.5 mm thicker than the Brembo discs used by BMW Motorrad. Problem solved! No further distortion or problems with these discs..
No idea whether you can do the same or similar as I don't know if a matching Brembo Serie Oro replacement exists for your K50 model but at least you have one more idea / input regarding the dissatisfying behaviour.
R1200GSRider
im wilden Süden
keins
Thank you
Hi Stefano, maybe the same issue as here… (Bremsprobleme GS 1250).
I hope google translator helps…
StefanoVisentini
Thanks for sharing your experience with me. I think I will go to a non-BMW technician to evaluate and replace the floating discs and bushings with aftermarket Brembos.
I think it may be a more durable solution than BMW.
A thousand thanks
StefanoVisentini
Hallo zusammen! Ich hoffe die Commiunity hier kann mir helfen!
Mein Motorrad der Marke BMW GS 1250r gibt mir seit einiger Zeit Probleme mit der Bremse am Vorderrad. Zur Zeit hat mein Motoread 14000 km gefahren und seit ung. 2000 km gibt mir die Vorderradbremse bei niedriger Geschwindigkeit (<30Km/h) ruckartige Bremsbewegungen, als wuerde die Bremse loslassen und wieder greifen. Obwohl der Bremshebel nicht losgelassen wird. Dies geschieht aber nur wenn sanft gebremst wird. Die Abnutzung der Bremsbacken ist zur Zeit nur sehr gering und die Bremsscheiben sind in sehr gutem Zustand. Auch fahre Ich keine Bergstrassen, sondern nur Autobahn.
Die BMW Werkstatt hier in Italien sagt, dies ist eine normale Abnutzungserscheinung und sieht keinen Grund zu intervenieren. Auch wenn noch Garantie vorhanden ist. Mir kommt das sehr komisch vor. Was sagt hier dazu? Gibt es jemanden, der Auch dieses Problem hat.
Danke und schoene Gruesse aus Italien
Stefano
manfred180161
manfred180161
Echterdingen
R1250GS Adv.Trophy 2023
Ciao Stefano und willkommen im Forum!
Du hast insgesamt 4 Beiträge geschrieben, alle zum gleichen Thema und es gibt auch Antworten dazu.
Warumjetzt schon wieder ein neuer Thread mit genau dem gleichen Problem?
StefanoVisentini
hello manfred.
I'm sorry, I know!
a friend advised me to translate it and write it in German to collect a greater number of participations even from native speakers. this is my truth. I am sorry. it seems to me only 2 posts one in english and one in german
MichaelBC
MichaelBC
88400 Biberach
1250 GS ADV Triple Black
As mentioned in the second post already this sounds very much like one or two warped discs. So your pistons get pushed back on every turn. This effect is less when you brake harder.
Check your discs with a gauge like this and come back here with the results.
GS-Swiss
GS-Swiss
Schweiz/SO
BMW R1300GS ASA; BMW S1000XR-M; BMW F800GS; Moto Guzzi V7III
Funny, I've had that with mine for a while. Just when I drive slower, for example, towards a red light and brake only very lightly, it brakes stronger, then less, again stronger, although I do not change the pressure. This is only when I pull the brake little strong. As soon as I brake harder, everything is normal. So just like with you.
Think you do not have to worry, so far everything OK. As I said, when braking harder, everything is OK. And if you brake only very lightly, it is a strange feeling, but in my eyes not tragic.
Assume if you brake hard, everything is also OK.
In my former case I had the same issue like mentioned already. Since I changed the discs years ago (about 40 Mm back from now) I have no more issues like before no matter how much pressure I do apply to the front brake lever.
So in other words an even behaviour under all normal circumstances (i. e. no race track use) is achieveable according to my experience (see #2)..
MarcosPC
Então, você já resolveu ou descobriu qual é esse problema?
Atualmente, estou tendo EXATAMENTE o MESMO comportamento e estou em guerra com a concessionária, eles dizem "é normal".
//Mod edit:
Haben Sie das Problem gelöst oder herausgefunden?
Ich erlebe derzeit genau dasselbe Verhalten und streite mit dem Händler, der sagt: „Das ist normal.“
GSler1973
GSler1973
Augsburg
BMW GS Rallye
Leute, nutzt doch bitte den Google translator oder deepl!
problem mit den GS r 1250 bremsen - Ähnliche Themen
  • Oops Wir sind auf ein Problem gestoßen
    Oops Wir sind auf ein Problem gestoßen: Ich bekomme andauernd diese Meldung Oops Wir sind auf ein Problem gestoßen An error occurred while the page was being generated. Please try again...
  • Hilfe oops wir sind auf ein problem gestoßen
    oops wir sind auf ein problem gestoßen: Ich bekomme andauernd diese Meldung Oops Wir sind auf ein Problem gestoßen An error occurred while the page was being generated. Please try again...
  • Neues Forum gs-forum.com Server Problem?
    Neues Forum gs-forum.com Server Problem?: Mir ist aufgefallen, dass das neue Forum (GS-Forum - Das BMW Motorradforum) scheinbar seit ein paar Tagen eine Fehlkonfiguration des Servers hat...
  • Geschwindigkeitsanzeige / ABS-Problem / F 650 GS - BJ: 2001 Km: 27500k
    Geschwindigkeitsanzeige / ABS-Problem / F 650 GS - BJ: 2001 Km: 27500k: Servus zusammen :-) Vorwort: Am vergangenen Sonntag war ich beim Offroad "freien Training" am Nürburgring. Bis dahin und während dessen alles in...
  • Navigator 5 Problem nach Kartenupdate
    Navigator 5 Problem nach Kartenupdate: Servus zusammen! Mein Navigator 5 zeigt nach nen Kartenupdate (auf City Navigator Europa 2026.20) letzte Woche die gewünschte Route nicht mehr...
  • Navigator 5 Problem nach Kartenupdate - Ähnliche Themen
