G650GS - weird problem
Diskutiere G650GS - weird problem im G 650 GS, F 650 (GS) und F 650 GS Dakar (Einzylind Forum im Bereich Motorrad Modelle; Hello everybody, recently i bought 2012 g650gs used, this morning was my first ride and i have come to a few surprises : Confused: First, not...
mcwelja
First, not always but often to be worried, when i put hard acceleration (when overtaking etc), at of no reason bike stops receiving power (throttle) and stalls, then stars again to receive speed. This cut of throttle sometimes produce that bike cut of power and i need to start by the road to start on bike again.
Second, i'm casually driving maybe 100km/h on 4-5k RPM... out of no reason , RPM goes to 8k (full) and light to change gear blinks. When i try to change gear, it wont let me, neither up no down.
Third, when i stop on red light, in neutral gear, a few seconds RMP are random, sometimes at 4k, sometimes at 5k and after 4-5sec it drops down to normal.
Do you maybe have some advices : Confused:: Confused:
Eckart
Eckart
F750GS 2019
First, you should check battery connections as they sometimes loosen which causes such things.
Second, there could be a problem with the rpm sensor. In the F650 forum, someone had metal shavings there, also check its connections.
The gear shift is mechanical only, so this is a different problem. While the motor is not running, it is normal that you cannot shift gears. You should check the clutch (see operating instructions how to adjust). If it works properly, it could be a serious and probably expensive problem with the gear shift.
To get more answers, you should look for a english forum or another ressource in english language, for example F650.com Home
Eckart
mcwelja
Here is the problem...
mcwelja
On small acceleration, it cuts out power, then turns back on. RPM on dash goes to redline, but RPM of engine is normal (3-4k), and after i press on clutch, RPMs on dash is stuck on ~4k and engine is running normal. Any thoughts?
G650GS - weird problem - Ähnliche Themen
  • Trägerlose Satteltaschen auf der G650GS? Enduristan, Rhinowalk, ...
    Trägerlose Satteltaschen auf der G650GS? Enduristan, Rhinowalk, ...: Hallo, fährt jemand auf der G650GS (oder F650GS) trägerlose Satteltaschen? Wenn ja, welche? Welche Größe? Hitzeschutz zum Auspuff? Montage...
  • Suche Wunderlich Tobinator Scheibenverstellung für G650GS
    Wunderlich Tobinator Scheibenverstellung für G650GS: Moin, ich suche eine Wunderlich Tobinator Scheibenverstellung für die G650GS. Beste Grüße Norman
  • Biete F 650 (GS, Dakar) Einzylinder G650GS
    G650GS: Original Scheibe, Luftfilter von Amazon und Givi Topcaseaufnahme für G650GS
  • Erledigt G650GS
    G650GS: Hallo an Alle Ich biete meine G650GS EZ 04 2016, Laufleistung 14.500km zum Verkauf an. Die Maschine hat 6 Vorbesitzer und mittlerweile scheint mir...
  • Erledigt Variokoffer F650GS /G650GS
    Variokoffer F650GS /G650GS: Moin zusammen, verkaufe meine Variokoffer + Träger für 350€ BMW F650GS / G650 Koffer Variokoffer + Kofferträger Liebe Grüße Basti
  • Variokoffer F650GS /G650GS - Ähnliche Themen
  • Erledigt G650GS
