Garmin Express Update Info
Diskutiere Garmin Express Update Info im Navigation Forum im Bereich Modellunabhängige Foren; Hi zusammen, Garmin Express Version 6.1.1.0 ist online.
Frank_B.
Frank_B.
32257 Bünde
1250er Exclusive / EZ 03/20
Hi zusammen,
Gatower
Gatower
Spandau b. Berlin
Zündapp KS 50, R90S, R80 GS, R 1100 GS, R1200 GS TB, R1200 GS LC Adv.,1250 GSA HP,04/21 40-Years GSA
Hi zusammen,
Garmin began rolling out Garmin Express v6.1.1 for the PC today. If you would like to update to the latest version, please visit the About page within the Settings of the Express application and select “Check for Updates to Express.” This version includes the following changes:
  • The vívofit jr. and jr. 2 can no longer be added to Garmin Express.
  • Other minor bug fixes and improvements.
eMTee
eMTee
Rhein-Main
Release Notes dazu:
- Users can now add a Monterra to Express if there is a SD card inserted.
- For Approach S1 users, we fixed an issue that would not allow the user to change courses following an update.
- Helped address an incorrect cycle map part number being installed to the Fenix 5x for AU/NZ users.
- Other minor bug fixes and improvements.
Gatower
Gatower
Spandau b. Berlin
Neue Version 6.3.0.0
Garmin began rolling out Garmin Express v6.3.0 for the PC today. If you would like to update to the latest version, please visit the About page within the Settings of the Express application and select “Check for Updates to Express.” This version includes the following changes:
  • Music files would not be included with the transfer of a playlist that was exported from iTunes. This was causing an error and has now been resolved.
claus1155
claus1155
Bei Wismar
K1300 Gt,Yamaha GTS 1000, BMW K 1600 Gt
Hallo, Mein Express hat noch 5.3.1.0 drauf,
ich soll akualisieren auf 6.1.1.0.
Das Uptdate bricht aber knapp vor der Hälfte ab.
Hat jemand eine Hilfestellung ?
claus1155
claus1155
Bei Wismar
Muß ich den alten Express ers vom PC entfernen ?
claus1155
claus1155
Bei Wismar
Funktioniert, Danke
eMTee
eMTee
Rhein-Main
Und was ist drin?
  • Added the option to use your iTunes Library to manage music within Express.
  • If a user backed up their favorites from an older Automotive device into Express, the file would go to the incorrect location and not appear on the new device when it would get transferred. We fixed this issue and now the file for your favorites will transfer to the correct location.
Option hinzugefügt, um Ihre iTunes Bibliothek zum Verwalten von Musik in Express zu verwenden.
Wenn ein Benutzer seine Favoriten von einem älteren Fahrzeuggerät in Express gesichert hat, wird die Datei an den falschen Speicherort verschoben und erscheint nicht auf dem neuen Gerät, wenn sie übertragen wird. Wir haben dieses Problem behoben und nun wird die Datei für Ihre Favoriten an den richtigen Speicherort übertragen
Weitere kleinere Bugfixes und Verbesserungen.
Reiner
an der Mosel
R 1150 R , F 800 R
es wird hier immer mitgeteilt, das es ein neues Update gibt.
Informiert Express nicht das es ein neues Update gibt ?
Also bei mir ist es so, wenn ich mein Navi mit dem PC verbinde, öffnet sich Express
und zeigt mir an, ob es ein neues Update gibt.
Ist es wichtig, Express immer auf den neuesten Stand zuhalten ?
Ich mache nicht immer sofort ein Update.
Gatower
Gatower
Spandau b. Berlin
Hallo Reiner,
das hängt von deinen Einstellungen ab.
Ich habe alles deaktiviert.
Ich starte GE nur wenn ich es benötige und ich will eben nicht jedesmal beim Anstöpseln, dass es aufgeht.
Siehe hier
Reiner
an der Mosel
R 1150 R , F 800 R
Habe ich gefunden...
Bei mir sieht GE ganz anders aus.
R1200GSRider
im wilden Süden
keins
...bevor Du ein Kartenupdate durchführst, würde ich auf jeden Fall die neueste Version von Garmin Express installieren.
Ansonsten ist da Update nicht zwingend notwendig, aber trotzdem ratsam...man weiß ja nicht immer, was alles gefixt wurde
Reiner
an der Mosel
R 1150 R , F 800 R
Ich habe mal ein Update gemacht . Erst GE und dann BC .
Danach war mein Navi routingunfähig.
Beim Update wurde im internen Speicher des Navi die Karte gelöscht.
Dank der Hilfe eines kompetenten Users im Garmin-Forum konnte ich Daten von der SD-Karte ins Navi
verschieben - danach war wieder alles gut.
Deswegen sträube ich einwenig überhaupt ein Update zu machen.
Garmin Express Update Info - Ähnliche Themen
  • Garmin Express 7.17.3.0 Update fehlgeschlagen
    Garmin Express 7.17.3.0 Update fehlgeschlagen: Frage in die Runde: Ich wollte heute, genau so wie sonst auch, das Garmin Express Update 7.17.3.0 auf den N5 und auf den N6 mit zwei verschiedenen...
  • Garmin Express Update Info für Win PC
    Garmin Express Update Info für Win PC: Neuer Fred zur besseren Übersicht mit neuer Bezeichnung jetzt 7.13.1.0
  • Garmin Express Update Problem
    Garmin Express Update Problem: Hallo, ich wollte gerade meine Karte auf meinem BMW N5 updaten. Gerät angeschlossen, G-Express geöffnet und nach Updates gesucht: Fehlermeldung...
  • Garmin Express Update schlägt fehl -> Lösung
    Garmin Express Update schlägt fehl -> Lösung: Falls jemand das gleiche Problem hat: Garmin Express ließ sich nicht mehr aktualisieren. Die Lösung war laut Support nur, das Programm zu...
  • Garmin Express Update hängt...
    Garmin Express Update hängt...: Liebe Gemeinde, mich verfolgt ein Problem. Ein Update von Garmin Express ist nie ohne Schwierigkeiten möglich. Ständig hängt sich die OP auf...
  • Garmin Express Update hängt... - Ähnliche Themen
