Shift Assist Problems
Diskutiere Shift Assist Problems im R 1200 GS LC und R 1200 GS Adventure LC Forum im Bereich Motorrad Modelle; 2016 R1200 GS I've been with my GS for a few years now. Generally a pretty perfect bike . The shift assist, when it works, is pretty perfect...
Mark-Hans
2016 R1200 GS
The shift assist, when it works, is pretty perfect. Super useful, no banging helmets and goes up and down like butter. Love it.
But, those are the good days. Other days he just refuses to work or works sometime and then jams. Really annoying when you go to tuck your toe under the lever and nothing happens..
This story has been going on for nearly 3 years and now I want a fix....
It has been implied.... the shift unit needs cleaning. So, I removed the middle bolt from the unit and disconnected the gear lever.
Should be able to ease it off and then unplug it....
It seems very very firmly placed on the gear-lever shaft........... Has anyone got any good ideas how to get this off without breaking anything! ....
Some advice and direction would be appreciated. Thank you.
R1200GSRider
im wilden Süden
keins
2016 R1200 GS
Hi, look at this manual to clean the gear lever
Probleme mit dem Schaltassistent
only cleaning, no grease!
The shift lever should return to its original position without resistance
Mark-Hans
Well, it turned out to be very easy!. There was washer broken inside of the selector unit!
Mark-Hans
Solved. This washer was stuck under the shoe on the Right!...
Mark-Hans
Thank you for the help and interesting links!...... sometimes a problem can be 'that' simple. Nothing got broken or damamged and I sealed the unit up with sealant (a tiny bit of it). Seems fine.
Rundreisender
F 750 GS, F 850 GS Adventure
I had quite similar issues, in my case the reason was, that the wire was broken, and the connection only worked sometimes. My BMW Motorrad dealer changed it for free (as it was quite a new bike).
Mark-Hans
Someone wrote that the system is horrible. This is my answer.
You are completely wrong and have no experience with the “shift assist”. Please note that this is a “support” and not an acquisition. Changing gears only takes 1/5 of a second, so very, very fast. The motorcycle maintains its posture and the electronics ensure that the engine speed is adjusted when downshifting. Impressive and it works perfectly, especially in wet weather. No popping or loss of speed, just press the selector lever and it goes up or down seamlessly. Having ridden for 50 years now, it is the best update since ABS on motorcycles. Have fun!.......I love it.
levoni
levoni
K50 2016 TB / SR500 / PX200
Jomar59
Jomar59
BMW F 900 XR
ich verstehe auch nichts, deutsches Forum, deutsche Forumssprache, warum schreibt man da englisch?
Gute Frage..Schreib mal Deutsch in einem Ami Forum. Mal schauen wie viele Antworten Du bekommst
Streiche Amerikanisch und setze: englisch... Wobei das meine Aussage ich keiner Weise schmälert
levoni
levoni
Des englischen bin ich schon mächtig. Aber der Inhalt passt nicht zu dem was vorher geschrieben wurde.
Mark-Hans
In einem internationalen Forum gibt es keine Einschränkung hinsichtlich der Sprache. Wir alle haben Google Translate. Seien Sie bitte etwas aufgeschlossener gegenüber anderen GS-Bikern.
Mark-Hans
Thanks again for your time and comments. Problem `solved and working perfectly as it should!. Have a good week.
Shift Assist Problems - Ähnliche Themen
  • Erledigt Wunderlich Blendschutz für 6,5 Zoll SLC TFT-COCKPIT mit SHIFT-LIGHT-CHANNEL
    Wunderlich Blendschutz für 6,5 Zoll SLC TFT-COCKPIT mit SHIFT-LIGHT-CHANNEL: Art.-Nr. 21083-102 Passend für viele Modelle mit o.g. TFT, einfach auf der Herstellerseite die Liste checken. Hatte ich nur wenige Wochen...
  • Quick Shift statt ASA
    Quick Shift statt ASA: Hallo, Ich hatte eben eine Probefahrt auf einer 1300 GS mit ASA. Den M-Modus fand ich im Vergleich zu dem Quick Shifter meiner K50 super. Der...
  • Umfrage: Wer würde Automatisierten Shift Assistent (ASA) kaufen?
    Umfrage: Wer würde Automatisierten Shift Assistent (ASA) kaufen?: Hallo zusammen! Da der bald erhältliche automatisierte Schaltassistent von BMW ja nun etwas ganz Neues bei dieser Marke ist, hier mal eine...
  • Automatisierter Shift Assistent (ASA)
    Automatisierter Shift Assistent (ASA): Das Geheimnis ist gelüftet… Mod edit: Shift Assistent
  • Erfahrung shift assist R1250GS und F850GS etc.
    Erfahrung shift assist R1250GS und F850GS etc.: Mittlerweile ist die 1250GS meine vierte BMW mit SA (3 K1600 davor) und auch zwischen den dreien gab es Unterschiede in der Leistung des SA. Bei...
  • Erfahrung shift assist R1250GS und F850GS etc. - Ähnliche Themen
