Navigator V
Diskutiere Navigator V im Navigation Forum im Bereich Modellunabhängige Foren; Topas, wieso glaubst du nicht einfach mal das, was dir gesagt wird? :wink:
Pillepalle12
Pillepalle12
Saarlouis
R1200GS LC
*Topas*
*Topas*
Schweiz/Berlin/Europa
GSA 1200 / 2011
ich bin von Hause aus.... ungläubig ;)
LC15
LC15
R1200GS LC
Ach ja, und das Kartenupdate nicht vergessen, seit heute gibts die 2014-30 zum download :)
DeeGee
R1200GS LC
Neue Firmware für Navigator 5 :
Changes from version 2.20 to version 2.50:Enhanced transferring of tracks between the device and BaseCamp. The active track log is now written to a separate file titled CurrentTrackLog.gpx.
Fixed issue that could prevent the map from panning or following the vehicle position.
Fixed issues that could cause large portions of the map to be blank or prevent the route line from appearing.
Improved vehicle icon position in North Up view.
Fixed issues that could cause voice prompt to say incorrect street name or destination name.
Fixed issue preventing the unit from speaking when the user presses the speak button on the mount.
Fixed issue that caused locations sent over Smartphone Link to appear with an incorrect name in Trip Planner.
Fixed issue that could cause Roadside Assistance feature to display incorrect information.
Enhanced proximity alerts volume to match navigation volume.
Fixed issue that could cause media to play at a different volume when switching tracks.
Fixed issue causing media tracks to play in alphabetical order after rebooting the device when random mode is selected.
Fixed issue that allowed the device to handle phone calls without an available audio output.
Fixed issue that caused the microphone to be muted in a new call when it was muted at the end of the previous call.
Fixed issue that prevented the device from reconnecting to Smartphone Link on iPhone when the device was turned on.
Added an option to Trip Planner to delete multiple trips from a checklist.
Fixed issue that prevented third-party routes transferred to the device through BaseCamp from recalculating.
Improved fuel tracking when moving device between a LIN mount and a non-LIN mount.
Fixed an issue that could cause the Large Buttons keyboard to display letters in the incorrect case.
*Topas*
*Topas*
GSA 1200 / 2011
ich zitiere mich ungerne selbst, aber irgendwie habe ich auf folgende Frage noch keine rechte Antwort gefunden...
ich hoffe, ich frage nicht doppelt....:cool:
ich hab das Gamin Zumo 660 in dieser Halterung.
Kann ich den N5 da unterbringen?
Das Zumo 660 ist ja identisch zum Navigator 4....
weiss das jemand?
:rolleyes:
DeeGee
R1200GS LC
N4, N5 und Zumo 600 bzw. 660 haben meines Wissens nach die gleiche Halterung.
Und wenn ich dein Bild so betrachte, dann sieht das gut aus für ein N5.
*Topas*
*Topas*
GSA 1200 / 2011
danke für die Antwort, :)
Peti
Peti
Schland
Die Pins müssen aber nicht zwangsläufig alle gleich belegt sein.
Da hilft nur stumpfes Ausprobieren.
Wenn der N5 und der 660 voll pinkompatibel sind, hätte man ja auch den Audio-Out und Audio-In wieder verfügbar.
Das wäre klasse.
Wäre schön, wenn Du Deine Erfahrung hier mal mitteilen könntest...
*Topas*
*Topas*
GSA 1200 / 2011
ich muss mal sehen, ob ich es morgen zum Gottstein schaffe, wenn er den den V er da hat...
evtl. klemmt er mir das Teil dann mal drauf..
:cool:
Edith sagt:
grad dort angerufen, keines vor Ort, wird nur bestellt geordert :(, das nächste kommt erst 2014
:eekek:
Mist, grad die Audioausgabe via alter Kabelpeitsche ist für mich unverzichtbar, da ich Blauzahn nicht nutze....
Und das muss funktionieren....
Ich hab kein Bock alles Kabel etc. neu zu kaufen bzw. zu verlegen....
Nutzt denn keiner hier eine TT Halterung? Evtl.ne neue, extra für`s V `er?
Tinu
Tinu
CH, Nähe Zürich
R 1300 GS Trophy
Hallo Topas
Das 4er/5er BMW Cradle hat nur eine beschränkte Anzahl überhaupt verbundener Pins (neben Versorgungsspannung und Masse) in Richtung Kabelbaum. Sprich 3 (Ich nehme an für den LIN-Bus, damit das Motorrad dem Navi all die Daten mitteilen kann die angezeigt werden können). Der Rest ist ungenutzt:
Wenn man ein Garmin 660er Cradle öffnet, ist der Stecker voll belegt. Am Garmin-Kabelbaum hat man ja die ganzen Anschlüsse:
ElchQ hier aus dem Forum hat ein Winterprojekt, den Garmin Kabelbaum ans BMW Cradle zu montieren. Technisch ist das eigentlich keine grosse Herausforderung, wenn man mal die Silikonmasse da rausgepopelt hat kann mans ja wechseln. Er geht davon aus, dass dann die kabelgebundenen Audio-Out Anschlüsse etc. genutzt werden können.
Musst ihn halt mal fragen bei Gelegenheit, wie weit das Projekt gediehen ist.
Grüsse,
Tinu
Tinu
Tinu
CH, Nähe Zürich
R 1300 GS Trophy
Ups sorry, meine "Antwort" war ein bisschen am Thema vorbei.
Ich hab auch noch ein 660er Crade am Zweitmoped (allerdings ohne TT Halterung), das ist mechanisch und elektrisch kein Problem. Nutzte ich mit dem IV und jetzt mit dem V.
Allerdings hab ich das ganze Kabelgeraffel vom Cradle abgeknipst und nutze nur noch die Stromversorgung. Daher kann ich nicht beantworten ob Audio über die Kabelpeitsche kommt, ich nutze nur Bluetooth mit dem Gerät.
Grüsse,
Tinu
*Topas*
*Topas*
GSA 1200 / 2011
genau diese Teil hängt ja an der TT Halterung....
wenn / falls ich zum N5 wechsle, möchte ich die Halterung gerne weiter nutzen, auch mit dem Hintergedanken für die kommende ADV,
ich kann mir fast nicht vorstellen, das Garmin die Belegung geändert hat.
Die TT Halterung find ich ziemlich gut, mal sehen ob man die an die K50 bekommt....
Grüsse,
Tinu
warum abgeknipst????
:eekek:
Ist doch reichlich Platz zum "verstecken"
Bollo
Sauerland
R1250GSA
Kleine Rückmeldung: Passt. Allerdings nutze auch ich Bluetooth, weiß also nicht wie das mit den Audioausgängen ist.
Da die originale V-er Cradle aber auch dafür nen Ausgang hat gehe ich davon aus das das auch klappt.
TMC funktioniert allerdings beim V nicht mehr mit Antenne. Dafür gibts jetzt die App.
*Topas*
*Topas*
GSA 1200 / 2011
Klasse Danke,
dann sollte das funktionieren:)
dann kann es hier ja weitergehen mit "zeigt her, eure Halterungen" ;)
Peti
Peti
Schland
Mein Dealer hat leider auch kein 5er zur freien Verfügung.
Sonst könnte ich das auch mal eben in die 660er-Halterung reinklipsen. Schade.
Ich möchte gerne auch mit Kabel weiter arbeiten...
*Topas*
*Topas*
GSA 1200 / 2011
ich versuche es morgen mal bei einem anderen BMW Dealer ....
Pillepalle12
Pillepalle12
Saarlouis
R1200GS LC
Jetzt mal ganz langsams, Jungs. Heißt das, dass der Ver im Zumo Cradle einen kabelgebundenen Audioausgang hat und dennoch alle anderen Funktionen funzen? Ich bin auch nicht so ein Freund von dem BT-Kram, hab lieber den Helm am Kabel. Allerdings möchte ich auf keinen Fall auf die Steuerung per MC und den Austausch von Fahrzeugdaten zwischen Rad und Navi verzichten.
Also, was geht?
Navigator V
Navigator V - Ähnliche Themen
  • BMW Navigator 5
    BMW Navigator 5: Hallo Gemeinde, ich habe vor mir so ein Teil gebraucht zu holen. Weiß jemand ob das Ding sich gemäß der SW- Versions-Stände (siehe Bild) ohne...
  • Navigator VI Austauschgerät HW V9 Display wird dunkel beim Einklicken in die Vorbereitung
    Navigator VI Austauschgerät HW V9 Display wird dunkel beim Einklicken in die Vorbereitung: Hallo, ich habe im Oktober 2023 eine neue R1250GS gekauft - inkl Navivorbereitung, die im Werk installiert wurde. Zu diesem Zeitpunk wollte ich...
  • Erledigt BMW Navigator V (5)
    BMW Navigator V (5): Biete BMW Navigator V mit BMW Case (Tasche) für 200€ zum verkauf. Eine Display Schutzfolie leg ich dabei. Er ist von 2019 und hat knappe 10000km...
  • Verständnisfrage: Handy und Helm wirklich mit beidem (TFT + Navigator) koppeln?
    Verständnisfrage: Handy und Helm wirklich mit beidem (TFT + Navigator) koppeln?: Hallo, ich spiele mit dem Gedanken, zu einer R1250GS Adventure zu wechseln. Und habe somit zum ersten Mal den TFT Bildschirm. Auf Youtube habe ich...
  • Carpuride an Navigator 4 Halterung?
    Carpuride an Navigator 4 Halterung?: Hi, habe gestern eine GS1 1200 aus 2009 gekauft. Da ist ein (antikes 🙈) Motorrad Navi 4 mit Halterung dran. Ich überlege nun 1. mir entweder...
  • Carpuride an Navigator 4 Halterung? - Ähnliche Themen
  • BMW Navigator 5
