Navigator VI neue SW 5.20
Diskutiere Navigator VI neue SW 5.20 im Navigation Forum im Bereich Modellunabhängige Foren; BMW Motorrad Navigator VI software version 5.20as of May 11, 2018 Use Garmin Express to install this file.(72.94 MB) View system requirements...
Gatower
Gatower
Spandau b. Berlin
Zündapp KS 50, R90S, R80 GS, R 1100 GS, R1200 GS TB, R1200 GS LC Adv.,1250 GSA HP,04/21 40-Years GSA
[FONT=&quot]as of May 11, 2018[/FONT]
[FONT=&quot](72.94 MB)[/FONT]
[FONT=&quot]View system requirements[/FONT]
Notes:
  • WARNING: If this software is uploaded to a device other than that for which it is designed, you will not be able to operate that device.
  • If attempts to upload software fail, you may need to return the device to Garmin® for service.
[HR][/HR]Change History
Changes made from version 4.90 to 5.20:
  • Added user consent for Travel History tracking per GDPR compliance.
  • Completed software modifications required to support Giantplus display configuration
  • Updated default brake debounce interval to 1 second from 10ms
  • Fixed an issue where if the power button was pressed shortly after the motorcycles ignition was turned 'off', the Navigator would permanently disable the screen
  • Greatly reduced the occurrence of phone audio echo
  • Removed 'Postal Code' from city search sample text
  • Added a new 'All Songs' option to the iPhone media source when browsing artists. This will allow user to select music which does not have an album tagged
  • Fixed a bug which caused teh Navigator to play BT phone audio to a headset even though it was muted
  • Modified 'Wipe All User Data' feature to remove all non-standard files and folders from the root directory of the devices
  • Removed duplicate text that can occur in imported POIs
  • Prevents music from playing automatically when a BT device disconnects and quickly re-connects
  • Removed a requirement for the user to acquire a GPS lock before EULA acceptance can be accomplished
  • Fixed a bug which prevented anonymous calls from working with newer iOS devices
MaAl
MaAl
Münsterland
R 1200 GS
habe das Update installiert.
Jetzt fehlt bei mir der Abbiegehinweis oben links, wenn ich eine Navigation gestartet habe.
Die Route wird angezeigt, indem der Weg pink markiert wird.
Die Hinweise, in wie vielen Metern/Kilometern abgebogen wird (oder welche Ausfahrt bei einem Kreisverkehr genommen werden soll), fehlt.
Weiß jemand, wie ich dieses "Piktogramm" wieder zurück bekomme?
Matthias
Pendeline
Pendeline
Westlich Stuttgart
R1300GS, R12G/S
Beschreibst du gerade das Abfahren der Route als Trockenübung im Gebäude oder real, draußen aufm Mopped mit Satellitenempfang?
Gruß von Pendeline
MaAl
MaAl
Münsterland
R 1200 GS
Moin Pendeline,
ich meine die reale Navigation.
Ich habe über die Zielsuche eine Anschrift eingegeben und bin dann die Route abgefahren und auf dem Rückweg habe ich als Ziel "Nach-/zuhause" eingegeben. Das Piktogramm war jeweis weg. Habe zwischendurch den N6 auch neu gestartet, keine Änerung.
Ist ziemlich blöd ohne die Pfeile, weil du immer auf das Navi schauern musst und wegen der geschwindigkeitsabhängigen Darstellung (Maßstab) nicht oder nur schlecht einschätzen kannst, wann die nächste Abbiegung kommt. Du siehst ja nur die lila Markierung auf der Karte.
Gruß,
Matthias
Pendeline
Pendeline
Westlich Stuttgart
R1300GS, R12G/S
Probier mal folgendes:
GPS-Simulatuin einschalten
Route laden und starten, bei der dein Standort am Startpunkt liegt..
Schauen ob die Piktogramme kommen
GPS-Simulation ausschalten
Schauen, was mit Piktogramm passiert.
nicht dass er einen Schritt zu weit ist oder auf die Karte getippt hatte. Leider nur das IPhone in der Hand. Pfeil nach links?
Gesendet von iPhone mit Tapatalk Pro
Gast-15146
In der GPS Simulation ist die Anzeige weiterhin vorhanden
MaAl
MaAl
Münsterland
R 1200 GS
Vielen herzlichen Dank, Pendelline!!!!!
Bin genauso vorgegangen, wie du beschrieben hast und siehe da, die Pfeile sind wieder da :o
MaAl
MaAl
Münsterland
R 1200 GS
Da habe ich mich wohl zu früh gefreut.
Nach der Methode/dem Tipp von Pendeline sind die Richtungspfeile zuerst da, aber nach rund 100 Metern berechnet das Navi die Tour neu. Nach der Neuberechnung sind die Pfeile dann wieder weg. Mehrfach probiert, immer das selbe Ergebnis. Übrigens, wenn ich den Simulationsmodus starte, dann bewegt sich das Symbol für mein Motorrad nicht mehr. Die Pfeile sind aber da. Seltsam, war vorher (vor dem Update) anders. Da lief es wie erwartet.
Habe hier noch mal die alten Beiträge gelesen. Andere User hatten dieses Problem auch schon mit dem N5.
Habe auch die dortigen Tipps, u. a. von Oerst, befolgt (Akku raus, Karten neu installiert, Dateien gelöscht und neu installiert). Alles ohne Erfolg.
Fakt ist offensichtlich, dass bei dem Update etwas schief gelaufen ist.
Ein User schrieb damals, dass er einen neuen Navigator bekommen hat.
Was mich jetzt interessiert: habt ihr ähnliche Probleme oder bin ich damit allein?
Ich vermute mal, eine springende Idee wird niemand mehr haben.
Werde die Tage mal zum :) fahren...
Ach ja, noch was. Vor dem Update hat das Navi mir immer die tatsächlich gefahrene Geschwindigkeit UND die erlaubte Geschwindigkeit angezeigt (z. B. 89/80). Wenn ich zu schnell war, wurde die vordere Zahl (die tatsächlich gefahrene Geschwindigkeit) rot angezeigt. Das ist jetzt auch nicht mehr da. Jetzt zeigt es nur noch die tatsächlich gefahrene Geschwindigkeit.
Mit dem letzteren könnte ich ja leben, aber eine Navigation ohne die Pfeile ist echt blöd.
Gruß,
Matthias
Gast-15146
ich war am WE auch unterwegs mit geplanter Tour und neuer Tour berechnet vom N6 und kann das alles nicht bestätigen. Er läuft so wie vor dem Update.
oerst
oerst
LEV
R1300GSA TB
Meines Erachtens liegen die Daten in den jcv Dateien, wie zB auch die Geschwindigkeitsgrejzen.
Aber die zu löschen und neu zu installieren hast Du laut Post oben ja schon versucht...
Mehr kenne ich momentan auch nicht.
Frank_B.
Frank_B.
32257 Bünde
1250er Exclusive / EZ 03/20
Letzten Samstag bin ich meine Hausrunde gefahren, keinerlei Probleme mit dem Navi 6.
Vorher hatte ich schon die Firmware 5.20 sowie die mit angebotene Textdatei installiert.
MaAl
MaAl
Münsterland
R 1200 GS
Danke für eure Antworten.
Ich hatte das befürchtet, es liegt wohl an meinem Navi.
In diesem Fall ist der Freundliche mein Ansprechpartner.
Ich weiß aber, dass andere User diese Probleme nicht haben.
@ oerst, ja, es waren die jcv-Dateien.
Pendeline
Pendeline
Westlich Stuttgart
R1300GS, R12G/S
Nach der Methode/dem Tipp von Pendeline sind die Richtungspfeile zuerst da, aber nach rund 100 Metern berechnet das Navi die Tour neu. Nach der Neuberechnung sind die Pfeile dann wieder weg. Mehrfach probiert, immer das selbe Ergebnis. Übrigens, wenn ich den .
Warum sollte das Navi eine gestartete Tour neu berechnen?
Bitte mal 2 Einstellungen setzen:
->Einstellungen ->Navigation ->Neuberechnungsmodus ->Aus
->Einstellungen ->Navigation ->Wegpkt. aut. überspr. ->Aus
Dann nochmal versuchen.
Gruß von Pendeline
MaAl
MaAl
Münsterland
R 1200 GS
Hm, das mit der Neuberechnung macht mein Navi häufiger, obwohl ich die angezeigte Route nicht verlassen habe.
Du hast aber Recht, Pendeline, beide Einstellungen sind tatsächlich gesetzt.
Werde ich heute Abend direkt ausprobieren und berichten.
Gast-15146
->Einstellungen ->Navigation ->Wegpkt. aut. überspr. sollte auf Ein stehen
oder was ist der Hintergrund deiner Empfehlung
Pendeline?
MaAl
MaAl
Münsterland
R 1200 GS
Wenn ein Wegepunkt übersprungen wird, muss das Navi neu rechnen.
Es wird Pendeline darum gegangen sein, dem Navi (vorerst) keine Gelegenheit zu geben, eine Neuberechnung durchzuführen um zu sehen, ob der Pfeil bleibt.
Wenn dem so wäre, könnte man den Fehler eingrenzen, wenn man irgendwann die Einstellungenwieder ändert und der Pfeil wieder verschwindet.
Pendeline
Pendeline
Westlich Stuttgart
R1300GS, R12G/S
Pendeline?
Ja, habe ich.
Der Effekt ist, das du bei jedem Abweichen von der Route von x Metern (Pinkelpause, 100 m von der Route entfernt) einen Countdown von X Sekunden (20 sek glaube ich) bekommst, wo du dies Funktion stoppen kannst. Falls nicht, skippt das N6 den nächsten Alarmwegepunkt aus der Route und berechnet vom Standort zum nächsten Wegepunkt neu. Wenn keine Alarmwegepunkt mehr in der Route drin ist, geht es vom Standort direkt zum Routenziel. Das sollte man bei der Routenplanung berücksichtigen, wenn man dies Funktion scharf geschaltet hat.
Gruß von Pendeline
Gast-15146
@Pendeline
Das bedeutet aber auch, dass man die manuelle Funktion "Überspringen" im Display braucht, um z.B. einen WP zu überspringen.
Dem Zumo 595 war das einfach egal und er hat egal was man gemacht hat stur die Route abgefahren.
Gast39385
Gruß,
Matthias
Hallo Matthias,
Garmin hat dieser Tage noch einen "Text"-Update nachgeschoben. Hast Du den schon installiert?
Klaus
Navigator VI neue SW 5.20 - Ähnliche Themen
  • Erledigt BMW Navigator VI V9 Neu
    BMW Navigator VI V9 Neu: Verkaufe meinen neuen Navigator VI in der Hardwareversion V9. Das Gerät ist jetzt mit einem kapazitiven Display ausgerüstet und daher nicht mehr...
  • Erledigt Navigator VI so gut wie neu
    Navigator VI so gut wie neu: Habe hier noch einen Navigator 6. Wurde im August von Garmin getauscht. Ist also mit dem schwarzen Menü. Hatte ihn nur auf einer Tour als Backup...
  • BMW Navigator VI.....seltsames Verhalten am neuen Fahrzeug
    BMW Navigator VI.....seltsames Verhalten am neuen Fahrzeug: Moin Forum, mein BMW Navigator VI hat bis zum neuen Fahrzeug, eine BMW F 900 GS, immer einwandfrei funktioniert. Kein Ghosting und/oder sonstige...
  • BMW Navigator VI.....seltsames Verhalten am neuen Fahrzeug - Ähnliche Themen
