GS-911 Update
Diskutiere GS-911 Update im Technik & Bastel-Ecke Forum im Bereich Modellunabhängige Foren; Hex GS-911 --> OCTOBER 2024 SOFTWARE AND FIRMWARE UPDATES DETAILS: GS-911 Diagnostics v2410.2 GS-911WiFi Firmware v300; Datapack v282...
Frank_Pfalz
Frank_Pfalz
Vorderpfalz
DETAILS:
Here’s what you can look forward to:
  • Sporty Instrument Features: Owners of BMW bikes with the XKOMBIHI Instrument Cluster, like the R1250 GS/GSA, can now configure some sporty instrument features on their BMW adventure models—features usually found on sportier BMW bikes. For example, you can now activate the Shift Light, adding a dynamic, sporty feel to your ride.
  • Enhanced Navigation: You can now enable your XKOMBIHI instrument cluster, to use the BMW Connected app.
  • Easy Troubleshooting: If you come across a fault code during an autoscan, you can now click on helpful quick links (while connected to the internet) to access a troubleshooting page on the HEX server. This page will describe the likely symptoms and causes, along with suggested steps to resolve the fault.
  • Service Reminder Customisation: We’ve expanded service reminder support to more models, including the R12 and CE02. This makes it easier to reset service reminders yourself.
  • WiFi Connection Alerts: If the WiFi connection fails, you’ll now hear a long beep, along with a red LED light, so you’ll know right away.
  • Support for More Models: Added features for BMW Nav Prepare Retrofit/Remove and expanded support menus for models like the CE02, R12, R12 nineT, R1300GSA, 2021 G310, and 2022 C400.
  • Improved Downloads: ECU links are now included in downloaded autoscans and PDFs, making it quicker to navigate within the files
  • Better Controller Management: The autoscan now checks for missing controllers and provides warnings if something expected isn't detected.
  • New Network Test Panel: Available in the PC Diagnostics App for easier connectivity testing.
QUELLE
P
PropellerAtze
Nürnberg
R 1250 GS
als kleiner Anhang, meins wurde letztes Wochenende eines Updates unterzogen und es geht schon wieder weiter
GS-911 Software 2410.3
GS-911WiFi Firmware 2.56 -0.300, Datapack V 283
Frank_Pfalz
Frank_Pfalz
Vorderpfalz
JANUARY 2025 SOFTWARE AND FIRMWARE UPDATES
SOFTWARE UPDATE DETAILS:
  • GS-911 Diagnostics 2501.4 -----------------> (2025-03: 2502.3)
  • GS-911WiFi Firmware v304; Datapack v291
Customise Your XKOMBIHI Display
Lithium Battery Health Monitoring
Enable & Disable the Alarm with Your Keyless Fob
Seamlessly Integrate Alarms and Tyre Pressure Controllers
Tyre Pressure & Temperature Monitoring for More Bikes
New 2024 BMW Models Added
Autoscan Menu Enabled by Default
Improved Autoscan Progress Display
Frank_Pfalz
Frank_Pfalz
Vorderpfalz
June 2025 SOFTWARE AND FIRMWARE UPDATES
  • GS-911 Diagnostics v2505.3
  • GS-911WiFi Firmware v306; Datapack v294
Exciting New GS-911 Software Update – Available from 28 May*!
We’re thrilled to announce a brand-new software update for the HEX GS-911, packed with brilliant new features and improvements
for BMW motorcycle owners and workshops.
The update will be rolled out to all GS-911 users from Thursday, 5 June 2025.
This release includes long-requested coding options, handy new service functions, and wider model support
GS-911 Update
GS-911 Update - Ähnliche Themen
  • Erledigt Hexcode GS-911 Diagnosetool für BMW R F K Serie R 1200 GS, F 800
    Hexcode GS-911 Diagnosetool für BMW R F K Serie R 1200 GS, F 800: Hallo Zusammen, verkaufe ein Diagnosetool von Hexcode GS-911. Mit diesem Gerät lassen sich bei der BMW die Fehler auslesen, Fehlerspeicher...
  • Erledigt Diagnosegerät GS-911 WiFi-Version
    Diagnosegerät GS-911 WiFi-Version: Diagnosetool für (fast) alle BMW Motorräder mit dem Runden OBD-Stecker (gibt auch einen Adapter für die eckigen). Sehr hilfreiches Tool! Ich...
  • gs-911: Fehlercode ohne Fehler
    gs-911: Fehlercode ohne Fehler: Hi @ all, mein gs-911 zeigt mir nach einem scan immer wieder (schon zug mal zurückgesetzt) diesen Fehler obwohl Heckleuchte sowie Bremslicht...
  • GS-911 Frage zum Twist Grip reset
    GS-911 Frage zum Twist Grip reset: Habe heute mein GS911 bekommen. Den Schaltasssistenten habe ich bereits erfolgreich damit reseted und neu angelernt. Schaltet nun viel...
  • Suche Hex GS-911
    Hex GS-911: Hallo, suche ein Hex HS-911 OBD2 WiFi Diagnosegerät. Wer sowas rumliegen hat und loswerden will, bitte per PN melden. MfG Chris
  • Hex GS-911 - Ähnliche Themen
  • Suche Hex GS-911
