CaptainPiQard
Ich habe es gerade im Naviboard gelesen. Mein WebUpdater lädt gerade...
Hier die Infos von Garmin:
Change History
Changes made from version 3.80 to 3.90:
Guido
Change History
- Corrected spontaneous shutdowns that could occur when satellite reception is temporarily lost.
- Corrected intermittent issue with music not resuming after a navigation prompt when paired to A2DP headphones.
- Corrected some languages not showing up on the unit.
- Corrected problems with the turn arrow in More Map View.
- Corrected a shutdown that could occur while reviewing off road tracks.
- Corrected an issue that could cause the unit to not shut off when connected to external power.
- Corrected importing only the first 650 points of some off road tracks.
- Corrected incorrect color on Netherlands Topographic Map.
- Corrected an issue calling some POIs.
- Corrected a possible shutdown when searching for cities.
- Corrected unit freezing when reviewing some POIs.
- Reduced the volume of the proximity alarm tone when using a headset.
Guido
....genauso wie 3.80 gelaufen hat...ohne Probleme....
...Fast immer wird die " Blauzahn" Verbindung ...wieso auch immer...nach einigen Sekunden Gesprächszeit unterbrochen...Finde keinen Fehler...
