mr.spock
- Dabei seit
- 09.02.2005
- Beiträge
- 55
Für jeden, des es betreffen kann (falls noch nicht bekannt)
Dietmar
GrussBMW R1200GS, RT, ST Motorcycles
Date: 04/04/2005
Supplier: BMW Group Australia
Category: Motor Vehicles
Product Info: Retrofitting cover for throttle-cable pulley.
Defect details: During product monitoring on R1200GS, R1200RT and R1200ST motorcycles, it has been determined that there is the possibility of small objects such as a pebble for example, or the cover of the A-arm pivot if it were to work loose becoming lodged between the throttle valve stub and the engine block. A foreign object lodged in this position could block the movement of the throttle cable pulley.
Consumer action: Contact BMW Group Australia on 1800 813 299
Make: BMW
Model: R1200GS, RT, ST
Model Years From: 29/03/2004 to 23/03/2005
Consequences: Within the framework of quality monitoring, BMW Motorrad has ascertained that there is a possibility of small objects such as a pebble, for example, or the cover of the A-arm pivot, if it were to work loose, becoming lodged between the throttle-valve stub and the engine block. A foreign object lodged in this position could block the movement of the throttle-cable pulley, and this in turn could result in a critical situation on the road.
Campaign Number: 00 00 13 10 00
Vin Range From: From ZL25391 to ZL28585; from ZM01042 to ZM02914; from ZL80112 to ZL81117.
Dietmar
