MapSource 6.15.3 ist da
Diskutiere MapSource 6.15.3 ist da im Navigation Forum im Bereich Modellunabhängige Foren; Hallo, seit heute früh liegt das MapSource update auf 3.15.3 zum Download bereit: http://www8.garmin.com/support/download_details.jsp?id=209...
Bearloe
Bearloe
Celle
Change History
Changes made from version 6.14.1 to 6.15.3:
Fixed an issue where blank map tiles are left on the screen.
Fixed an issue with redrawing the map after a detail level change.
Enhanced the drawing of roads to better distinguish primary from secondary roads.
Added the ability to adjust symbol size of icons.
Fixed the display of spot soundings in Marine maps.
Fixed an issue with areas getting highlighted inadvertently.
Fixed 'Move Waypoint', 'Insert Route Section', and 'Extend Route' capabilities from right-click context menus.
Fixed an issue with water regions getting clipped.
Limited 'Nearest Features' to only displayed maps.
Fixed overlapping copyright information for certain maps.
Fixed the display of certain Marine icons in the 'Find Nearest Places' dialog.
Fixed an issue with improper amenities getting displayed for 'Exit Properties'
Modified the color used for bathymetric lines.
Enhanced the look of dashed and dotted lines.
Enhanced sizes of certain labels.
Enhanced the look of road shield icons.
Fixed an issue when using certain find operations.
Fixed an issue where changing the font would result in no labels being displayed.
Fixed an issue with using the Roads & Rec 2.1 Hawaii and Alaska product
Ausführlich diskutiert wird das Thema im Naviboard:
http://www.naviboard.de/vb/showthread.php?t=33630
und im Naviuser-Forum:
http://www.naviuser.at/forum/showthread.php?t=1131
Schönes Wochenende
Bearloe
Bearloe
Bearloe
Celle
Installiert und läuft bestens :)
Hallo Klaus,
wie ist das Verhalten bei der Neuberechnung einer gespeicherten Route? Auf dem Rechner eines Freundes verabschiedet sich die Version 6.15.3 leider :mad:
Bearloe
Bearloe
Bearloe
Celle
hat Dein Freund ggf. beim Start einen RunTime Error? Dann hat er wahrscheinlich freie Karten eingebunden, wie ich auch.
Hallo Andi,
auf meinem PC habe ich dasselbe Verhalten beobachtet: Bei Neuberechnung existierender Routen stürzt Mapsource 6.15.3 ab :mad:.
Nein zu deiner Erklärung: Es ist kein RunTime Error, es sind keine freie Karten eingebunden.
Bearloe
sukram
sukram
Belgien
R1200GS 2007
No Problem,
Tolles Update endlich
Schnell, Flexibel,..
willi.k
willi.k
Bergisch Gladbach
R 12 G/S
Hab's auch mal schnell installiert,
ist nun deutlich schneller, ähnlich wie 6.13., prima!
Aber den mitgeteilten Absturz bei der Routenneuberechnung habe ich auch. Ist allerdings für meine Zwecke unerheblich.
Ich freue mich über die schnellere Performance.
Bearloe
Bearloe
Celle
Keine Probleme, Neuberechnung funzt prima :)
Hallo Klaus,
wenn ich die gdb-Datei vor der Neuberechnung im gpx-Format speichere, klappt die Neuberechnung :confused:.
Ein Absturz erfolgt übrigens auch, wenn ein Wegepunkt doppelt auftaucht.
Bearloe
Bearloe
Bearloe
Celle
alle, die freie Karten auf ihrem PC installiert haben, sollten mit 6.15.3 zurückhaltend sein, denn Mapsource verursacht einen RunTimeError und damit einen Absturz :mad:.
Bearloe
Wolfgang
Wolfgang
Bad Hindelang / Allgäu
R 1150 GS Adventure
Für mich ist dieses Update noch nicht zufriedenstellend. Absturz bei Neuberechnung, nur weil zwei gleiche Wegpunkte in der Route sind -inakzeptabel. Bei mir bleibt erst ein mal die 6.13.6.
Zum Probieren hab ich noch nen alten Rechner (aus zwei mach eins), den muss ich aber erst umbauen.
AndiP
AndiP
Hochsauerland
R100GS HPN, R80 G/S
wie weiter vorne schon geschrieben, ist der RunTime Error kein Problem. Hiermit werdet Ihr geholfen:
http://www.path.cz/forum/viewtopic.php?f=20&t=387
Lesen kann das eh kaum einer, einfach downloaden, installieren, Karten die den Error verursachen ausfindig machen und Fehler korrigieren. Feddich :-)
Schimanski
ich bin seit zwei Tagen stolzer Besitzer des 550 und hab gestern mapsource auf dem PC installiert. Blöderweise ist alles in englisch. Gibt es eine Möglichkeit, das ganze auf deutsch umzustellen?
Grüsse
Schimmi
Mister Wu
Mister Wu
1150 GS & 1300 GS
Habe jetzt ein bisschen rumgespielt.
Keine Probleme bisher. :rolleyes:
Biji
MOin,
ebenfalls keine keine Probleme bisher (läuft bei mir unter Parallels/XP). Neuberechnung etc. eben getestet, alles fein.
Nur RoadTrip macht richtig Stress wenn man mit zuvielen Waypoints & POIs arbeitet, ist ohnehin eher lahm und fühlt sich noch immer wie eine Beta an.
MapSource 6.15.3 ist da - Ähnliche Themen
  • Garmin GPSMAP 278 und Windows 11 / Mapsource
    Garmin GPSMAP 278 und Windows 11 / Mapsource: Hallo, Entsprechend meinem old school style bin ich immer noch mit einem Garmin GPSMAP 278 unterwegs. Mein Windows 7 Rechner kann natürlich...
  • OSM-Karten nach Basecamp/MapSource übertragen
    OSM-Karten nach Basecamp/MapSource übertragen: Hallo Leute, ich habe eine Frage zum Thema: wie kopiere ich eine OSM-Karte nach Basecamp oder MapSource? Ich habe mir auf der Seite BBBike...
  • Neues Laptop - Übertragen der Daten von MapSource bzw. BaseCamp
    Neues Laptop - Übertragen der Daten von MapSource bzw. BaseCamp: Hallo! Ich muss mit meinen Programmen und Daten auf ein neues Laptop umziehen. Habe bisher alle mir wichtig erscheinenden Ordner kopiert und auf...
  • Neuling! Routenplanung Garmin Zumo 390LM - BaseCamp/Mapsource
    Neuling! Routenplanung Garmin Zumo 390LM - BaseCamp/Mapsource: Hallo an alle, hab mir jetzt gestern ein Zumo 390LM bestellt, da mir das Fahren nach Landkarte einfach zu stressig und auch gefährlich war. Da...
  • Problem bei update für Garmin Zumo 210 und Mapsource
    Problem bei update für Garmin Zumo 210 und Mapsource: Problem bei update für Garmin Zumo 210 und Mapsource Moin! Ich hab folgendes Problem: Nächsten Sommer...
  • Problem bei update für Garmin Zumo 210 und Mapsource - Ähnliche Themen
