Wer hat Erfahrung mit dieser Hupe?
Diskutiere Wer hat Erfahrung mit dieser Hupe? im Zubehör Forum im Bereich Modellunabhängige Foren; Stebel Magnum Horns (Passt die unter den Schnabel einer BMW 1150GS?)...
Gast1869
Summary: With a sound tone that is similar to the Fiamm Freeway Blasters, the Stebel Magnum horns have slightly less volume but also offer an authoritative tone.
We purchased the Stebel Magnum horns in England at Nippy Normans, who said they were rated at 139 dB, a figure that we now know is so off the mark that it's laughable.
The Stebel Magnum horns have a slightly higher pitch than the Fiamm Freeway Blasters; the high/low pair have claimed 500 Hz and 410 Hz frequencies, compared to the Freeway Blaster horns at 485 Hz and 405 Hz.
The factory claims 115 dB, but we measured only 81.9 dB at 2 feet away, a variance of -33.1 dB.
The Stebel Magnum horns somehow feel lighter than the Freeway Blasters, even though they're not; it may be that their shape makes them seem lighter.
The silver plastic cover on the back of the Magnums was unattached on one horn and loose on the other when we purchased them, and the horns overall seemed like they are built to lower quality standards than the Fiamm horns.
But they still sound pretty good, with a car-like tone. Mounting should pose about the same level of complexity as the Freeway Blasters.
Not much else to say about these, they would probably work fine if nothing else was available, but they just didn't make a big impression on us.
Stebel Magnum .MP3 Sound File: Stebel Magnum (0:0:14) |​
AmperTiger
AmperTiger
Dahoam
Stebel? hatten wir hier noch nie :D:D:D was ist das?:cool::cool:
Gast1869
Hallo Jean,
ich selle fest, dass du meine Frage RICHTIG gelesen hast.
Danke für deine qualifizierte Antwort. Ich werde hbokel mal anschreiben und meine Frage stellen.
Eine Frage noch:
Warum hast du deine Magnum nicht/noch nicht eingebaut? Siehst du da Probleme?
Kannst du was zu dem TON des EINZELHORNS sagen? Der Soundfile ist zwar gut, aber persönliche Erfahrungen sind besser.
peter-k
peter-k
Singapur
R 1200 GS / 2007
Meine Meinung zur Magnum (persönliche Erfahrung): Nicht besonders laut aber vom Ton her mehr Autorität als die Serientroete. Ein Magnum Horn alleine klingt für meine Ohren armselig, wenn man das mit dem Doppelhorn vergleicht.
Gast1869
Danke Peter,
und was würdest du vorschlagen, welche Hupe ich verbauen könnte?
Die Nautilus mag ich nicht, und zwei Hörner an der 1150 GS unterzubringen ist wohl nicht ganz so einfach.
Snoppy14
Snoppy14
Brandenburg
R1200GS LC und MV Dragster RR
Ich hab die Nautilus, dank fachmännischer Hilfe des Forums rechts unter der Verkleidung verbaut.
Gestern war mein Motorrad zum Tüv , habe mal in der Werkstatt die Hupe kontrollieren lassen, war lustig, alle waren wach......:D:D
Gast1869
Ist das etwa eine quasi "Nautilus"?
Bosch Airmaster Kompakt-Zweiklang-Fanfare
Die Bosch Airmaster Fanfare ist eine der kompaktesten Kompressor Fanfaren auf dem derzeitigen Markt. Der Einbau ist so einfach wie bei einem Horn, ohne lästige Schläuche mit nur einer Verbindungsschraube.
Technische Daten:
Lautstärke: 115 dB(A)
Tiefton: 530 Hz
Hochton: 680 Hz
Spannung: 12 V, 24 V
Leistung: 220 W
Wenn ich mir das Bosch-Teil ansehe möchte ich wetten, dass da irgendwo steht "made by FIAMM". Auch die Details sehen der Nautilus verblüffend ähnlich. Nachdem Bosch wohl kaum Plagiate vertreiben wird könnte das ein Zukaufprodukt sein ....
peter-k
peter-k
Singapur
R 1200 GS / 2007
Nachbau des Stebel Nautilus. Getze wird in Deutschland auch schon frech kopiert, von renommierten Firmen ...
Ich find die Hupe vom Astra recht laut, hat ein Motorradkollege an seiner V-Strom. Das ist auch ein Doppel aber selbst eine davon fand ich noch recht laut. (Das Pärchen kostet hier etwa 40 Euro.)
Roter Oktober
Roter Oktober
Freie Hansestadt Bremen
Moin, hab die Fanfare von der R1150RT BJ. 2000 verbaut, gefällt mir vom Ton und Lautstärke besser als das Lufthorn und funzt ohne Anmeldung beim Steuergerät.:)
für Fahrzeuge mit
Doppelhorn
X563A=Ja
06 Fanfare Tiefton 420HZ / 1 / 61337655881
06 Fanfare Hochton 510HZ / 1 / 61337655882
G-B
Ich hab mir in der Bucht günstig so ein Doppelhorn von nem Astra Cabrio geholt.
Habe ich bei meiner R100GS an die Stelle der normalen Hupe plaziert. Geht gerade so beim Einfedern.
Jetzt hören mich die Dosenfahrer gleich. :D
Gerhard
Gianni1
@ sepia-f: jetzt hast Du ja schon ein paar Infos bekommen und ich schliesse mich meinen Vorrednern an, die Magnum ist besser als die original Tröte, (Kunststück:D) aber noch weit von einer Doppelhorn Fanfare entfernt.
Ich selbst habe sie noch nicht an der GS verbaut weil ich den O-Stecker von BMW nicht abschneiden wollte.
Habe dann im Album von hbokel gesehen dass er die Magnum mit einem O-Stecker verbaut hat und wollte Ihn daher um ein paar Tips bitten.
Meine "Favorit" war/ist allerdings auch die Doppelhorn Fanfare die ich auch auf meinen RT's hatte und daher gleich die Frage an:
@ Roter Oktober kannst Du mir/uns ein paar Tips oder Fotos geben wie du die Doppelhorn an deiner GS verbaut hast?
Wie hast Du das mit der Verkabelung gelöst und hast Du evtl ein Relais benutzt.
Sorry, viele Fragen aber für eine Hilfestellung wäre ich Dir sehr dankbar.
Jean
Gast1869
Danke Gianni1,
ich tendiere, neben der Magnum, auch zur Doppeltonfanfare. Aber wohin mit den beiden Hörnern?
Deshalb die Frage auch von mir an Roter Oktober:
Wohin mit den Hörnern?
Und die Bitte um Bilder o.ä. Ich schließe mich voll und ganz der Bitte von Gianni1 an.
Vorab schon mal ein DANKESCHÖN.
Roter Oktober
Roter Oktober
Hier das gewünschte Foto, angeschlossen an die normale Zuleitung vom dem original Horn, ohne Relais und ohne Anmeldung am Steuergerät.
Gianni1
Danke Andreas!:)
Ja, so geht's, bei der ADV hat man auch etwas mehr Platz und Möglichkeiten als bei der normalen GS.
Ich denke wenn man die beiden "Hörner" unter der Verkleidung anbringen will wird's wohl eng.
Ich werde wahrscheinlich erst mal die "Magnum" dranmachen und dann schau'n mer mal.;)
Jean
Roter Oktober
Roter Oktober
Moin, die Hörner besser nicht im direkten Einfederbereich montieren, das wird zu eng bei einer Bodenwelle. Hab ich gemacht:mad:, war mal gleich ne neu Lackung für den Fender fällig*. An den Seiten geht es weil der Fender da durch geht.
* volle Ausladung und sehr zügig in Dolos unterwegs
MacZep
MacZep
R 1200 GS, R 100 GS PD
Hallo Roter Oktober!
Mache mir auch so meine Gedanken zu einer etwas lauteren Hupe. Die von der GS ist ja nicht lauter als ein Hasenfurz. In den Beiträgen habe ich die Airmaster Kompakt-Zweiklang-Fanfare von Bosch als laute Lösung und als einfache Lösung die Hupe vom Astra Cabrio gefunden.
Kann man die Hupe vom Astra einfach einbauen? Ohne Anschluß an die Batterie?
Danke schon einmal vorab.
G-B
das mit der Hupe von nem Astra war ja ich.
Folgendes:
1. hab ich ne R100GS-PD. und die hat so eien flache Einzelhupe. Das ist nicht meine aber eben so eine. :D
2. Hat meine alte gs schon ein Relais für die Hupe. (Da ich den Griff mal zerlegt habe denke ich, bei der Konstruktion werden alle mit der Amatur ein Relais drin haben). Deshalb hab ich mir einfach ein Y-Kabel gemacht und die beiden Hupen einfach an die alten Anschlüsse dran gemacht.
3. Sind die nebeneinander am Originalplatz festgeschraubt. Geht bei meinem 21er Vordereifen und dem niederen Kotflügel grad so.
Somit hab ich jetzt ne Dosen-Doppelhornhupe.
WIe man so etwas (baut doch sehr breit) bei einer anderen GS verbaut kann ich dir nicht sagen.
Wer hat Erfahrung mit dieser Hupe? - Ähnliche Themen
  • BMW F800GS (Bj. 2011) – sporadischer Komplettausfall von Tacho/Display während der Fahrt – wer kennt das aus eigener Erfahrung?
    BMW F800GS (Bj. 2011) – sporadischer Komplettausfall von Tacho/Display während der Fahrt – wer kennt das aus eigener Erfahrung?: Hallo zusammen, ich habe seit kurzem bei meiner BMW F800GS, Baujahr 2011, ein sehr merkwürdiges Problem: • Während der Fahrt fällt das...
  • F 900 GS wer hat Erfahrungen mit Sozia?
    F 900 GS wer hat Erfahrungen mit Sozia?: Hallo, wie im Titel schon erkennbar, interessieren mich Eure Erfahrungen mit Sonia auf der F 900 GS. Und ja, es gibt Leute die Tatsächlich auf...
  • Wer hat Erfahrungen mit (Hartschalen) Dachzelten?
    Wer hat Erfahrungen mit (Hartschalen) Dachzelten?: Hallo, für unseren Kastenwagen (VW Crafter L3H3) überlege ich gerade, ob ein Dachzelt eine gute Alternative für kurze Übernachtungen ist. Ich habe...
  • Wer hat Erfahrung mit USA mit eigenem Moped?
    Wer hat Erfahrung mit USA mit eigenem Moped?: Hallo, ich möchte mit meiner GS 2 Monate die USA erkunden. Meine erste Idee war eine BMW, möglichst eine GS, zu mieten. Das hat nicht...
  • Wer hat Erfahrung mit MOTEA - Komfort Sitzbank Gel passend für BMW R 1200 GS 04-12 Tourtecs TG35
    Wer hat Erfahrung mit MOTEA - Komfort Sitzbank Gel passend für BMW R 1200 GS 04-12 Tourtecs TG35: Hallo, da mir beim Fahren bereits nach ca. 30 Minuten das Steißbein anfängt zu schmerzen, habe ich mich auf die Suche nach einer Komfortsitzbank...
  • Wer hat Erfahrung mit MOTEA - Komfort Sitzbank Gel passend für BMW R 1200 GS 04-12 Tourtecs TG35 - Ähnliche Themen
